Hiring
How to Nail the Technical Interview for A Remote Job
Illustration of a woman attending a video interview
Since joining Toggl as a mobile software engineer, I’ve helped the company hire 10+ engineers from a growing pool of candidates. The team is 100% remote, which means our hiring pool is, well, the whole planet. This also means that all of our communication takes place over the internet. Our hiring interviews are no different. The popularity of remote work means it’s crucial to nail the interview.
During my time at Toggl, I’ve sat through countless interviews, both good and bad. I can offer you some practical tips on how to prepare and make sure that you blow your interviewer away!
👨🏽‍💻 Make sure your software won’t stab you in the back
Since there’s already a lot of physical and digital distance between you and the interviewer (video latency, possible language barriers and the fact that you’re not in the same room to read body language), you need to make sure that nothing else gets in the way during the interview times.
Two hours before the interview, make sure to restart your computer, as this fixes 99% of the tech industry’s problems, check for OS updates (we’re looking at you, Windows 👀) and test your camera and headset in the platform that you’ll use for the video call.
While most interviewers probably expect some minor disturbances, these problems might make you even more nervous which can significantly affect your ability to function during the interview.
💻 Do a recap of your developer environment
Programming code
It doesn’t matter how senior you are: writing a Hello World from scratch, in the environment and technology you’ll use for the test, will make you more productive when doing this in front of the interviewer – a bit like when you rehearse before doing public speaking.
This will also ensure that you don’t waste your time fighting environment errors, which can be perceived negatively. I know computers are hard and sometimes they act up, but the last thing you need during an interview is to fix configuration problems instead of showing your skills!
😯 Don’t see the interviewer as your enemy
A common misconception during interviews is the assumption that the interviewer is trying to trick you. If that were the case, why would the company be hiring in the first place? The interviewer is another human being, like yourself, and they’re looking for the best people to fill the position.
The very fact that you were invited to the interview should already mean something. Maybe you have a kick-ass resume or you nailed some kind of online test; it doesn’t matter! Remember you are being interviewed for a reason and don’t let that imposter syndrome kick in.
🤔 Not knowing things is not a problem
When you join a remote team you need to learn how to trust people. This means you should never be afraid of saying: I don’t know. I can’t stress this enough. If a person says they don’t know the answer to a question, that’s completely fine. If they make things up just to pretend they know the answer, that alone tells me not to trust that person and is a huge deal breaker.
This also extends to using a new, hype framework/architecture versus working with what you know. If you’re given the freedom to choose, show what you already know then mention your knowledge of the other method. This will let the interviewer know that you’re not oblivious about technology without making you look like a liar.
🔈 Communicate, communicate and then communicate some more!
Another indispensable pillar of remote work is communication. It doesn’t matter how good of a developer you are; if you’re unable to communicate, you’re not a good fit for a remote team.
Before you even consider writing your first line of code, make sure you correctly understand the interviewer’s requirements and expectations. Remember: they’re not your enemy!
Do they want you to complete in time regardless of code quality? Or maybe they want you to show how you’d build a real-world application. Is performance more important than code readability or the other way around? Knowing what interviewer expects is key to impressing them, so make sure you get it right!
During the interview, explain what you’re doing as you’re doing it. This will show that you’re able to communicate and helps the interviewer understand your thought process. If you’re doing something in a less than optimal way and plan to refactor later, let that be known (as long as you have the time)! Don’t be shy. Remember, the interview is the only way to show that you’re a good fit!
🌴 Understand that remote work is still work
interview-remote-beach
Please, don’t mention things like: “I just wanna work from a beach in Bali” or “I need this job because I wanna focus less on work”. To be clear, it’s okay to have those aspirations! Work-life balance is important. If working from home can help you with that, you should look for a remote job! However, you have to remember that remote work is still work, and it’s still a job interview.
The interviewer wants to know how you can contribute to the team and the company. If you only focus on the remote part and forget the work part, it’ll sound like you only want to relax and not get anything done.
Instead of focusing on the benefits of remote work, mention any prior experience you have working from home. Show the interviewer that you’re self-motivating, organized, and not easily distracted. This will get you a lot closer to your goal than saying you want to be in one of those stock photos of people drinking margaritas on a beach!
🎁 Wrapping up
These are the tips that helped me hiring new people and getting myself hired. If you feel like something in this article is wrong (or if you have something to add) feel free to contact me!
Last but not least, we are hiring.
By On May 29, 2019
  1. This article was great to read thank you! Such good tips and I completely agree with what you’ve said. I still get very nervous and still forget that interviewers aren’t just there to scare me off so thank you for that reminder that they aren’t my enemy!
    One thing you could add in would be about having questions ready but I’m thinking that wasn’t in this article because that’s is something you’d want to do for any interview hey!
    Thank you again, I look forward to reading more blog posts in the future and if you are looking for a Customer Support person I would love to take your Toggl Hire test(assuming you don’t use Hundred 5 anymore?) in the meantime, LinkedIn is going to send me an alert if you post any jobs… hopefully! haha
