New Ways for Connecting Your Favourite Apps with Toggl and Zapier
Zapier now lets you add tasks and tags to the Toggl time entries you create from other apps, and use templates when automatically creating your projects.
Toggl and Zapier integrations for Trello, Asana, Slack and Teamweek
In case you haven’t heard of Zapier yet, it’s a tool that lets you build integrations between your favourite web apps using a dead-simple UI.
How to connect Toggl with my other apps?
To start using the integrations, simply log into a Zapier account and connect whichever tools you need with their API – which can be done with the push of a button.
Go on, try one of these popular choices to test it out:
Now Zapier’s added a couple more options to their Toggl integration, which I think you’ll find pretty neat.
Create Toggl projects from templates
Project templates let you build commonly used project set ups in seconds.
Imagine you want to create a new Toggl project automatically whenever you create one in Asana. Pulling an existing template lets you skip having to log into Toggl to change the project’s billable rate, tasks or team assignments:
creating toggl project from template with the zapier integration
Automatically add tasks and tags to your time entries
The benefits are pretty obvious here. Instead of starting a simple time entry when performing an action in another app, you can also specify tasks and tags to be automatically included in these entries:
adding tasks and tags to automatic toggl time entries
All in all, Zapier has hundreds of apps in their inventory, so chances are you’ll find your favourites there (no matter how obscure they may be).
Also, while we’re on the topic of integrations, be sure to check out our insanely popular Toggl Button browser extensions for Chrome and Firefox!
By On January 23, 2017
