Update: As of February 2017, the Toggl Pro is known as the Toggl Starter plan. Have a look here to compare our existing pricing plans!
If you’ve got a Toggl Pro subscription, you can now add custom billable rates for your team members!
This is something you guys have been asking about for a while – and we’ve heard you.
In the past, you could define a default hourly rate for the whole workspace, or set a custom hourly rate for a project or a project member.
But this new feature adds a lot more flexibility for those of you using time tracking with teams – especially if your fees are calculated by the hour.
Introducing team member rates
To give your team member a custom hourly rate, simply head to the “Team” tab and select “edit” at the checkbox in front of their name. This is what you’ll see:
Don’t be disheartened by that Business feature note – that only applies for editing the other personal details. Adding team member rates is available to all Toggl Pro users!
How does it work?
In short – the team member rate adds another level of hierarchy for calculating billing in your reports.
For example – if you’re using a default workspace rate but think Debbie up there is worth a bit more, Toggl’s reports will reflect that. But if Debbie does some work on a project that pays a bit less than her normal fee, you can set a custom rate for that project:
In that case Toggl will look at the project’s rate instead of Debbie’s. And adding custom rates to the project’s members in turn overrides the project rate.
What else is new?
If you’re using the Toggl Android & iPhone apps, have a look here for an overview of the latest updates. Or, if the Toggl Desktop app is your productivity tool of choice, well then we’ve been working on that one too.
We also have a brand new support page! Head over there to get answers to any questions you might have (or email our customer support aces at support@toggl.com).
Also would love to see custom rates per task. I need to charge my client machine time (for rendering) that is at a different rate from active work.
Great addon!
Next up use a cost per hour/team mate for profit modeling? ๐
Another vote for custom rates for various tasks within a project thanks!
since updates constantly crashing and freezing to the point where it has become unusable.
and the interface is so much less user friendly – particularly with regard to tags.
I want the old one back!
Yay! Thank you!
UGHH. The desktop app has been freezing up several times, and it looks like I’ve lost time that I thought I was tracking. Guys, I appreciate the updates, but this has happened more than once with updates. I need something that I can RELY on, or I’m giving away my time.
Hey Tami, sad to hear you’re having these problems. Could you please write us at support(at)toggl.com so we can look into this? Also would be great to know if it’s the WIndows or Mac app, and which version. Thanks ๐
hi,
Are there privacy issues with the hourly rate? I mean, does other team members can see others hourly rate? Is there a setting we can set the privacy..
Thanks!
Hey, you can change who can see billable rates on your “workspace settings” page: http://support.toggl.com/workspace/ the setting toggles between “admins” and “everyone”.
By default, only admins can see the rates, so you should be good ๐
Need custom rates by tasks/tags.
I checked again, the custom rate works properly now. Maybe my browser cache needed to be refreshed.
Is the team member custom rate a pro plan feature or business feature? I have a pro plan and I can’t edit the rate of my team.
Another point about the blog: I cannot log with my google or facebook account to add a comment.
Renaud, team member rate is a pro feature – but if youลe having trouble with the feature, please contact our support (support@toggl.com) and they’ll look into the issue.
As for G /FB login, they’re indeed not working properly atm – but thanks for telling us anyway ๐
