Helpful hints #3: Finishing a project
Next in the series we have the ending of a project. Once all work on a project is done, the only thing left to do is archiving it. This way you can clear up your screen for new important things.
Let’s get to it then. For example, let’s close the Application design project for Small client.
Finishing a project #1
To do that, you must first click on the project name. This will open up the Edit project view.
Finishing a project #2
Here click on the Close project button which will pop up a confirmation question.
Finishing a project #3
And you’re done! The project is closed and hidden from view.
Finishing a project #4
Now if you wish to see your closed projects, click on the Show inactive projects link and there you have it.
Finishing a project #5
From the Edit project view you can reopen the project, too, if necessary. And that’s all there is to it 🙂
By On August 31, 2007
  1. I just learned about closing out projects today and started chipping away at them, but through in the towel after while. I have 175 more to close out.
    Is there a way to close out projects in bulk?
  2. Hi Dan,
    All the pictures above are from the standard free version. Could you please send us a screenshot of your ‘edit project’ view so we could look into this? The e-mail address is support [at] toggl.com and we’ll look into it ASAP.
    Best,
    Kristel
  3. Is the ‘edit project view’ shown above from the premium version? I don’t see how to add users in the standard version. I’ll wait on more testing until I find out the answer.
