How To Add Time Manually in Toggl
NOTE: Here is a quick visual guide on how to manually add time entries in Toggl.
Entering time entries manually has been very problematic for some users, so we have improved this. There is a new link – “add manually” – just above the start-button:
By clicking this link the following will happen:
  • The time entry area turns grey to indicate the manual entry mode.
  • Time entries added this way will not start tracking.
All other functionalities are left unchanged. You can return to the normal, timer mode by clicking the “use timer”-link in the top right corner of your dashboard. Your selection will be saved and you will continue in the same mode you left off next time you log into Toggl.
Let us know what you think of this new feature with the “Ask a question”-link inside Toggl or the comments below!
By On May 4, 2011
